typo_joe
Hello All! Some of you may have been following my previous thread. I'm going to stop updating there because it has moved passed the sub/amp advice I was originally asking for and has turned into a build thread. So, here's my build thread.
The skinny:
• Truck: 2013 1500 Express Regular Cab Short Box 2WD
• Head Unit: Stock uConnect 3.0
• Mids and Highs: Stock (possible upgrade later)
• Amp: Kicker CX1200.1 (to be purchased next week)
• Sub: 12" Eclipse Aluminum Cone (discontinued)
• Line Out (LOC): AudioControl LC2i
• Wiring: 4 gauge (brand TBD)
• Box Finish: Color Matched Carpet
The Goal:
• Clean Crisp Bass
• Stealth/Hidden as possible
• As perfect as I can afford
• Maintain as much storage space as possible
• Maintain center console function
• Maintain majority of drivers seat adjustability (comfort is 1st priority)
• Use the storage trays factory mounting points
If you want to see what I've done to this point, please see my previous post.
http://www.ramforum.com/f51/looking_reg_cab_sub_amp_advice-31557/
Where I left it, I was going to tweak my current box plan with the consideration of removing the storage tray. The plan is, officially, going to remove the storage tray. It will be replaced with a custom built tray that will also be carpeted to match the box/other interior.
As you may be able to tell on the attached photo, there are two false walls on the sides of the box. The false walls don't have bottoms. These are to hide the wires running from the top.
I have four main concerns:
• Mounting everything on the box. I think I'm going to devise some rubber feet/pads to use as spacers, but exactly how, I haven't figured it out yet. If anyone has suggestions, please share. Major.
• Space for the wiring on top of the box. I wont start constructing until I get all the components. That way I can do some dry fitting to be sure I have the space. Major.
• Building the tray. If the wall was flat, it would be easy, but thats clearly not the case. Keeping up with the contours and keeping it clean are going to be tough given the condition of table saw. At least the carpet will help conceal some of it. Major.
• The overall width of the box portion is 22". It should be fine, but I hope it doesn't poke out from behind my seat too much. Minor.
The dodge's that run on the sides of the front panel... well I'm not sure what those are. I added them on another version of the build (that I haven't shown). One of them was kind of needed for balance but, but now they are just there. I don't know if they will end up on the finished product or if they do, I don't know how I'll do it. Most likely something 3-D as opposed to inset.
I'm sure I'm leaving something out, but here's where I am.
The next steps:
• Order Amp
• Build 3-D Mockup of new design (overall dimensions w/o tray)
• Dry fit components
• Finalize Design
• Begin construction
Once I'm convinced the box design will suit my needs, my focus will be on a clean run of the wires. Mainly the power, but really every wire there is. I would prefer that only the few inches of wires shown on the rack (before wires go into the false walls) are the only wires that are seen unless you either move the seat up or open the hood. From what I've inspected so far, this should be a lot easier than my jetta. Fingers crossed.
About the attachment: Ignore the black rectangle on the front unfinished view, that was my measuring tool from when I was figuring the volume. I forgot to delete it. It does hide the 11.125" hole shown for the subwoofer.
The skinny:
The Goal:
• Clean Crisp Bass
The next steps:
• Order Amp
• Finalize Design
