Update stock sub?
Beamer
Anoka, MN
I have a 2012 Crew Cab with the Alipne upgrade and sub.
Any possible upgrade using the stock sub box?
300MAG
Don't think there much you can do with the stock enclosure. Not much depth and the most you can get in there is a 8" sub if I recall correctly.
Sent from my Desire HD using Tapatalk 2
Beamer
Beamer
Anoka, MN
Well I dug into it last night, and what is in there is a 8" dual voice coil sub. The option on the window sticker might say Alpine, but the back of the speaker has a Chrysler emblem on it, and says made in China.
Anyway, I think one could make a decent upgrade to the sound by either using a separate amp for just the sub (supposed to be 509watts for the whole system with the Alpine option) but to me the sub fades alot.
I'm not trying to shake windows, just would be happy if the bass didn't drop off so much when you turn up some decent rock music.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
well its an OEM woofer, made by Alpine for Daimler...is the woofer a dual 2 or 4?
Beamer
Beamer
Anoka, MN
No spec's on it at all. Not sure how to measure impedance with a meter or anything (I'm a machinist, not an electrical engineer lol)
Beamer
Beamer
Anoka, MN
I would assume that it is 4ohm on each coil, as they ran wire all the way from the dash, thru two connections (2-wires each) into the box all the way up to the speaker itself. If they were running bridged / mono, etc... they would only run one pair of wires.
audio1der
Airdrie, Alberta
A lot of newer stock systems run 1ohm subs too, for space/efficiency reasons. I had a 6.5", 1 ohm sub in my car.
I think the biggest drawback would be the space contraint, providing you could give a new sub aftermarket power.
Have you considered something like this?http://www.ddaudio.com/products/mobile-audio/woofers/sw65.aspx
I'd rather have a really high powered 6.5" in an appropriate enclosure, than an adequate 8" in an enclosure barely big enough to meet minimum requirements. (plus, DD makes an awesome product!)
EDIT- just watched a vid with 2 of these bad boys; impressive! https://www.facebook.com/photo.php?v=335513849870752
Pete
Blue Bell, PA
I have been thinking about this as well. May end up going to the local custom shop and having a box built.
5.7L HEMI
A single Kicker solobaric L7 would do wonders in the small space.
Graygoose
Oklahoma
Convert, for now.
small
while the L7 'will' work in the small sealed, I'd prefer to see them in a larger ported box. Now the CVX or Solo Classic would be perfect.
Larry313
Tennessee
I bought an 8" Memphis Audio sub and tried putting that in the box using the stock amp...no good so I bought a small Pioneer amp to run it and it hit pretty good but the box is junk and you could hear the air escaping. So i ordered a custom box (really 2 boxes one for passenger side and one for drivers side) I only used the passenger side and it takes 10" subs so I took back the 8 and got a 10. Also to make room for the box I had to remove the cover/door under the seat. It sounds way better than stock, now i just have to sell the drivers side box to recoup some of that money. All said and done it cost about $500.
PS the amp fits behind the box on the floor nicely.
Oh and I still use the stock head unit, I used a line out convertor on the speaker wires that ran to the original sub.
