Upgrade 5” screen
Jds morgan
Houston
Diesel
I have a 2023 Big Horn 3500 and came with a 5” screen. I would like to upgrade the screen size . The dealer told me that a Larger screen would fit. Then they said that they are not allowed to preform this upgrade and would not place the order. Has anyone done an upgrade? If so, did they use OEM screen or another supplier.
tron67j
Maryland
Read through the 8.4 upgrade thread here in the Gen 4 forum. Essentially you need a 8.4 bezel upgrade that you can get from Infotainment, suggest springing for the added volume control. Then need the steering wheel audio kit, see Benny in the allmoparparts posting in the vendor section. You may also need a wiring harness, see M²Mods also in vendor section. And finally the 8.4 radio that you can order new from Benny, source from Infotainment, or in my case I did upgrade with unit from salvage truck I found on car-parts.com used parts website. Pretty simple upgrade, pop off current bezel, take out radio, install new radio with harness if needed, and pop new bezel on.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
All this ^^^
but I wouldn't recommend infotainment. Benny and M2Mods (forum members @AllMoparParts.com and @Mpgrimm2 respectively)can get you everything you need to upgrade without the inflated price (and poor support) from infotainment.
Is your truck a 5th gen (new body style) or 4th gen classic?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Markmitchell71
