See the truck in my sig pic? 6" lift. No break lines necessary.
Quote from BDS's website on a 6" lift for your truck.
"Bump stop drops, anti-sway bar extensions, 3 point differential drop system, front stainless steel brake lines, and strut relocation brackets are also included in this Dodge 6" lift kit."
Quote from BDS again for current generation trucks. 4 and 6 inch kits.
"The system also includes bump stop drops, anti-sway bar links, 3 point differential drop system, strut relocation brackets, and front stainless steel brake lines."
Quote from BDS on the 4" air ride kit on new air ride trucks.
"In order to accommodate for the full height range of the adjustable suspension, front replacement brake lines are also included."
Quote from Zone 4" and 6" lift installation instructions.
"Attach the provided brake line relocation bracket to the frame where the original
line mounted. The brakeline bracket will offset towards the rear of the vehicle.
Torque the factory bolt to 10 ft-lbs and the ½" bolt to 50 "
Quote from Rough Country on their 4 and 6 inch installation instructions.
"Install new brake line bracket onto brake line using supplied 5/16” x 3/4” bolts, washers and nuts. "
Granted, I'm sure some of these lines and extensions are more for precaution, but they have them in all of these lifts.
Links-
http://bds-suspension.com/product?ma=2&mo=16&ty=13&yr=2006-2008
http://bds-suspension.com/product?ma=2&mo=16&ty=99&yr=2013-2016
http://bds-suspension.com/product?ma=2&mo=16&ty=96&yr=2013-2016
http://zoneoffroad.com/display?ma=16&yr=2014&mo=166&ca=78
http://www.roughcountry.com/dodge-suspension-lift-kit-323c.html
Sent from my VS990 using Tapatalk
