Upper center console
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
How do you remove the upper center console that holds the garage door opener? I was I stalling LED lights and knocked something loose inside and need to disassemble to fix.
Thanks!:big_banana_Dance:
jagr200
2013 Sport
Slide your fingers under the trim around the black piece and pull it down. It will come right out.
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Just make sure you do this at the end closest to you, not the windshield. There are hooks on that end that will tear through your headliner if you pry from that end...
joshhhh
