Upper glove box
tex68w
6.7L CTD
Looking to add the upper glove box to a 2021 3500. I have P/N 6YK08TX7AA for the glovebox itself, but is anything else needed? How do you go about removing the current parts in order to install it? I saw videos on adding it to the older 4th Gen trucks but I haven't come across any for the 2019+ 5th Gen.
tron67j
Maryland
I did 4th Gen, so can't exactly relate bit would imagine it is about the same. You can reach out to Benny at allmoparparts, he will make sure you have the correct part number. It comes as a kit with the new box, door and light. The connector for the light on the 4th gen was taped up near where the new light is, so if you take current cubby out and poke around, you should see a green (I think) connector. I would follow 4th gen for removal and see how similar it is, I also don't see it for 5th gen yet in a video. Good luck.
T
tex68w
6.7L CTD
Yea I watched both of those for the 4th Gen. I'll try the same process for the 5th Gen and see how it goes.
Fpye
