Vararam install problems
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
So this Vararam is ******* me off, the instructions I have are sad. They couldn't make them colored so you could see what they have going on. I'm having troubles getting the front scoop to sit correctly without either hitting the horn or cooler behind it. Does anyone have pics of their intake so I can see what they look like? Mines not sitting down even and I'm not wanting to cut this intake.
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
2016 bighorn cc here.... no issues whatsoever. Directions were pretty simple.
sent from galaxy S7 edge using tapatalk
misuracaf10
I have a vararam and that looks the same as mine. Except my tube didn't come with a hole for the MAF sensor so I had to drill my own haha
1SilverBullet2
1SilverBullet2
North Dakota
Your guy's don't rub on the condenser lines at all? Mine does, you can see in my last photo. That's what is causing mine to not sit level. I'm assuming from the holes drilled that the textured parts of both pieces should be facing you? (As in the the small piece is installed on the backside of the top intake piece)
BrianandChrissy
Buffalo NY
Not at all.
1SilverBullet2
1SilverBullet2
North Dakota
Well Brian yours is a 16' and it's a little different than mine but what did you do with your horn and everything so it doesn't mess with the scoop?
eljefe
Moyock, NC
Mine is a 2014 and I had to trim on the left side to lay flat. It still has a lean, when the hood is up, because the vararam is sitting on the a/c hose across the front.
1SilverBullet2
1SilverBullet2
North Dakota
I'm gunna have to trim mine as well on the left side near the a/c lines so it'll sit flat too. I'm just surprised they wouldn't accommodate the intake for that.
BrianandChrissy
Buffalo NY
Enjoy
joshhhh
