Iasodbuster75
I'm wanting to wrap some trim pieces in my truck to closely match the truck color. My Ram is a '19 1500 classic in blue pearl streak. Does anyone know a close match?
Agree with this! I have a Blue Streak Pearl '17 Laramie and started this morning with just plain carbon fiber...I like the look but what a pain!!! I had originally thought about doing a blue also, but wasn't enthused by the look once I received it. It matched fairly close, but seemed as if it would be too much color. Here's the blue carbon fiber I ordered and returned for the black:IMO, with that bright color, I would go very subtle (few) interior pieces. Otherwise, it will look like an interior of a "2001 sport compact driven by a 17-yr-old"....
Thanks for the input. I need to rethink about my color choice. Especially being 44 and not some teenage kid.
https://www.amazon.com/VViViD-Electric-Carbon-Release-Technology/dp/B00FXYBBAG/ref=sr_1_4?crid=2EHI26O8NU0WN&keywords=blue+carbon+fiber+wrap&qid=1553609759&s=gateway&sprefix=blue+carbon,aps,208&sr=8-4
I took the entire assembly apart. That allows the vinyl to be wrapped around the inside completely. I took it inside as a large piece, then removed all the screws in the back to remove the vents, radio surround, etc...It's a bit of work, but very low cost!Did you have to take the radio surround completely apart to do it or did you do it still assembled? I seem to recall that it's plastic welded together.
-K
For the carbon vinyl wrap you did on the radio bezel trim, did you do it in place or remove the bezel? Did you then remove the trim from the bezel? Could you please post some details about how you did this? It looks great and I'd like to do something similar.Agree with this! I have a Blue Streak Pearl '17 Laramie and started this morning with just plain carbon fiber...I like the look but what a pain!!! I had originally thought about doing a blue also, but wasn't enthused by the look once I received it. It matched fairly close, but seemed as if it would be too much color. Here's the blue carbon fiber I ordered and returned for the black:
Did you mess with any plastic weld or were you able to get the trim off cleanly without breaking any welds?I took the entire assembly apart. That allows the vinyl to be wrapped around the inside completely. I took it inside as a large piece, then removed all the screws in the back to remove the vents, radio surround, etc...It's a bit of work, but very low cost!
