Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Since buying my 05 3500 Diesel the volt meter has always read high. My volt meter says things are just fine. So my question is, can just the volt meter be changed out or does the whole cluster need to be replaced as a unit?
The needle is pegged against the high side post. The voltmeter says 13.5 volts.
My question was about replacing the voltage gauge and that is what I wanted to know.
