Warlock fogs alternative
WaRam21
3.6 VVT
Like most warlock owners that weren't lucky enough to get their truck with foglights from the factory, I have been looking for ways to add them and not spend about 500 dollars. I ended up finding this alternative that might just work (fingers crossed). So I purchased the OEM bumper bezel fog light insert kit from ebay (pic attached) and some aftermarket fog lamps from a website and I'll post direct link down there. I'm hoping this works. I am a fan of OEM and was willing to go the whole 9 but I have seen that it's a headache so this will do for now. Then save enough money to just have the dealership install the factory ones with all the bells and whistles and the OEM headlight switch. I'll attach pics here as well and the install once everything comes in.
(https://m.bonanza.com/listings/halo...V9dsabsNMcL6vafVR-HvMIdRoXRPjY4AaAlTQEALw_wcB)
Mb7640
Fountian hills az
I just installed the factory led fog lights it did not cost my that much. I ordered the factory bezel., wiring harness, nut plates,screws for under two hundred dollars. Saying that I did not use a factory switch. I wired them on a separate circuit going to a auxbeam switch controller. They are way brighter than my headlights.
popipaker
Poland
2018 Rebel
any update?
WaRam21
WaRam21
3.6 VVT
any update?
Well... They're on now. But I had to do some modifications. Hardest part was removing the old bezels and installing the oem ones. But the fog lights I ordered didn't fit flush in the oem bezels. The pic they posted on the advertisement is false. I'll keep these until I can buy oem ones, wiring, etc. If anyone has gone with the oem please let me know how hard it is or an estimate on cost?
Mb7640
Fountian hills az
Looks good, I put in the oem fog lights I paid $54 for each light. Will be easy to just all since you already did the hard part installing the bezel. You should be able to replace them through the wheel well
WaRam21
WaRam21
3.6 VVT
WaRam21
WaRam21
3.6 VVT
Hey brotha quick question, what's the turnaround on the return for the ones i have on now? Thinking of ordering the OEM sometime in February but wanted to see if you can help me with finding the harness I'm gonna need and switch if possible. Thanks
Mb7640
Fountian hills az
I did not return them I was just so mad I through them in the trash. If you want the correct harness I would call one of those mopar parts places online. I already had the harness so I made it work. I used a auxbeam switch controller for mine. So far I have the fog lights and light bar hooked to that. Made it way easy no hassle. If you need the part number for the oem led fogs let me know
WaRam21
WaRam21
3.6 VVT
Yes if you have it thatd b great brotha, thank you.
DaWeiss
Bavaria
HEMI 5.7
Hello guys,
I want to put some fog light in my 2021 warlock, and for the fact that here in germany we hav problems with lights that are not state certified by the EU i want to look after some certified lamps in the aftermarket. So could one of you do me an favour and give me the exact measurement of hole the factory bezel?
Greetings from Bavaria
Christopher
errndog
North Carolina
V6
Did you also have to order the housing??
errndog
North Carolina
V6
So you were able to work through the wheel well and not remove the bumper??
TheM4rxxx
