you might consider products such as
What is the best windshield washer fluid for winter?
Prestone ® De-Icer Winter Windshield Washer Fluid is specially designed to improve winter driving visibility. It is formulated to melt ice & frost fast, down to -34°F. Prestone De-Icer washer fluid works hard to prevent dangerous refreeze.
What to put on wiper blades to keep from freezing?
De-icer Windshield Washer Fluid: Using a windshield washer fluid that is chemically formulated to prevent icing paired with newer “winter blades” that are coated in rubber can help diminish the amount of freezing. This solution should work well, but only when traveling below 35 mph.
Can you make winter safe windshield fluid?
The easiest way to modify your warm weather mixes for cold weather is to add alcohol. Because alcohol freezes at a much lower temperature than water, it can be more effective in cold weather. While rubbing alcohol is recommended, high-proof vodka can also be substituted.
Can I spray alcohol on my windshield to melt ice?
Rubbing alcohol!
Mix ⅓ water and ⅔ isopropyl or rubbing alcohol together in a spray bottle. Spray the solution directly onto your front and back windshield and watch the ice melt instantly. "Because alcohol has a very low freezing point, it causes the ice to break up and melt," explains Burkhauser.
