weak windshield washer spray
tobyd
Longmont, CO
3.0L V6 Diesel
Hi,
My 2015 has lost pressure in the washer spray -- weak spray coming out of the driver's side and zero from passenger's side. Any pointers on the most likely culprit? I do not see any leaks under the hood when it's spraying, so the pump maybe has gone bad?
Thanks
Toby.
crazykid1994
Are you using rainx or rainx additive? Could be clogged jets. These trucks gets clogged easy with Rainx unfortunately. I stopped using rainx and started just doing the windshield application of rainx and used the cheap Walmart washer fluid. No more clogs
Socalramfan
Huntington Beach
2011 Big Horn
Make sure the spray nozzles aren’t blocked as well.
Id start by making sure there’s fluid, then disconnect the line going to the first nozzle and see if fluid comes out when you select washer on.
if there’s fluid…… it’s not your pump, or line from the pump to the nozzle.
Next only connect one washer nozzle to the line you just checked, and test that. Process of elimination. Connect the remaining side and check that.
New nozzles are not expensive, but I’d definitely stick with Mopar. Haven't seen too many aftermarket ones last that long.
Zoe Saldana
california
6.4l
Hi,
Thanks
Toby.
Try ******
T
tobyd
Longmont, CO
3.0L V6 Diesel
Why yes I have been using Rain-x.. Hmm, will try to declog the jets and change the fluid.
fireflymedic
Fla.
V6
Same thing happened on my 2015. The tube had came off under the hood it's above the insulation so you couldn't see it. But water would run off under hood. So open hood and use washer see if water is leaking out above hood cover
T
tobyd
Longmont, CO
3.0L V6 Diesel
