What can i do to get more throtle responce out of my 2014 ram
WyattB
Pa
How can i get more throtle responce out of my 2014 ram without hurting my factory warenty would changeing the air intake void anything any input and ideas would really help me out on how to acheave what im looking to do to it
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
You are going to need a higher gear ratio or custom tuning to feel any real gains in throttle response at part throttle. Cold air intake, ported throttle body, and exhaust upgrades will show more power at WOT, but tuning and gears are the 2 parts that will show the most noticeable gains in response at part throttle.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Will the stability & tow mode buttons still function with the tuner programs?
WadXpress
HEMI
Tuner. Hemifever adds 20% throttle response to his tunes and it makes a difference. You can just add the throttle response without a custom tune
WyattB
WyattB
Pa
Wouldnt changeing gears void the warenty its prity much a new truck it onley has 4000 miles on it it still has factory warrenty plus extended im the typ of person that i cant just leave anything how it is i have to change it to make it mine
DRkNESS
South Jersey
Sadly in some instances if you want yo make it yours, you're going to run that risk. Some dealers will use any excuse as to not pay out when service work is needed. I paid my truck off the first year, but still waited until I was out of warranty to do any modding.
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
I would think you are correct unless of course you let the dealer do the work then they may warranty it! Not 100% sure but not worth the grief and extra expense imo! Good luck!
Zeak
2014 Outdoorsman
Changing gears wouldn't even be realized by the dealer and shouldn't hurt anything as far as warranty and the dealer is concerned...other than the rear differential of course.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Any aftermarket part you add can only void the warranty on that part if the dealership can prove that it caused a failure. This is a tough question though because every dealership is different...some could care less what parts you add where others will give you a hard time over just a drop in air filter. Swapping gears will only affect your differential, in which case, you would just take it back to the shop that did the install, not the dealership.
Paluby
Alaska
What gears do you have?
xrsman
Ontario
3.0 Ecodiesel
Just remember, you pay to play. If you get denied warranty it's your own fault.
That being said I'd start with a tuner, CAI and exhaust!
Sent from my SM-G920W8 using Tapatalk
Firebird
2019 Ram 2500
I installed a sprint throttle booster, absolutely love it!
GlenMcQ
