What could clean up this interior?
nlambert182
Huntsville, AL
Super Clean. Purple bottle, get from Walmart. Make sure to dilute heavily and make it stronger as needed. Rinse thoroughly. Great stuff and stupid affordable.
Eh... Super Clean works great as a degreaser, but if you're not REALLY careful with the dilution and know what you're doing, you can do some damage with it. I don't know that I'd spray it on an old interior.
Stoffregen Motors
Cool, CA
5.9 Cummins
I use it frequently, and yes, there are things it can disturb. Paint on plastic parts like gauge cluster or knobs, it may loosen that and cause it to wipe off. Aluminum and anodizing, if left on too long, it can discolor both. They say it can damage glass, but I've never had that problem.
I do use it to clean just about every other interior part though. Carpeting, floor mats, HVAC box and ducting, door panels, even the dash.
I should mention that I use a pump type spray bottle and different types of brushes, or sometimes no brush at all.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
Check out "the detail geek" on you tubes.
That guy cleans some of the nastiest stuff...you could at least see how he does stuff,not nessasarally the products he uses but the methods.
glsander
