Lookin' For a Used, Clean Pop Up Camper For my 3500. Which Are The Best Ones?
Goose55
Ajo, AZ
Cummins High Output 6.7L
I hemmed and hawed for a long time, but finally my senses came to me. My 3500 dually is over built for them but I finally decided I do not need a self contained, 5th Wheel or large slide in camper to do what I want to to in Arizona's summers. For stream and lake fishing, a simple, clean used pop up camper will do just fine. I won't be facing hot or cold temps, so I prefer a soft sided pop up--not the pricey Alaskan brand.
I had a little, tiny Skamper (cramper) pop up for my old club cab Tacoma, but the 3500 has an 8 foot bed, so this will be a huge improvement over that. And, NO more swaying side to side as my rig has a 7,500 pound payload! I won't even know it's on the truck.
There are many made now. Which brand, decent quality pop-ups should I look for? I'd prefer not a wood framed one, but steel or aluminum framed, for durability.
THANKS MUCH!
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
I would look at Northstar truck campers. We've had two. Currently have a heavily optioned 850SC with the Sub-Zero package. They have both pop-up & hardside options. Great company built in Iowa. northstarcampers.com
Chukbacca
Orange County CA
If you’re looking for all aluminum… you might look at the Livin’lite Quicksilver. Alternatively, If you are tall, like I am… you may want to hunt around for a “high wall “ a few manufacturers have made them over the years. I had a Fleetwood Niagara that I could stand up in with no problem at all and I am 6‘5“.
There is also a forum called pop up portal that you might look around in for ideas. I will also share that the pop up princess has a fantastic buyers checklist.
Best of luck… I enjoyed my time with a pop-up, and look forward to doing it again in the future
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
second the Northstar.i looked at every pop up and the Northstar was a perfect fit for us.and the resale is really good.
Mike Wenrich
Mariposa, Ca
2004.5, 2023 RAM 2500 Laramie 4x4
5.9 Diesel, 6.4 Hemi
I had a Northstar SC850on my previously owned 3500 with the Cummins and it was excellent. But...one thing I did not like was that it extended so far over the front it blocked my nav/radio when going two of the four directions. I got around that by adding a hood mounted receiver which pigtailed into the passenger post side wiring when the camper was on the truck. The only other thing I did not like was when the top is down, you cannot access the toilet. Found that out during the pandemic when you could not use a public restroom anywhere. Carry a pee bottle. Also the door is a bit tight (for a tall person) and I bumped my head a few times before I added some extra padding. The Palamino has a larger door but is not built as well. Lastly, if you are not 6' feet tall or above you might need a small step ladder to get to the roof tie downs on a 3500.
Gregf
