What did i do wrong HID pars question
TRIGGER_Hemi
So i have spyder headlights that are stock high beams and H1 low beams and they both run off one plug.
here are some pics i took did I need to order the H1 canbus or what
Im so lost first 2 pics are from the truck to the head lights
3rd is how the highs and lows run off one
T
TRIGGER_Hemi
more
iam_canadian22
northern ontario
With what you have you should just need h1 hid bulbs, you need the ballast to go with the trucks plugs which looks like you do, the output after the igniter will be 2 amp connectors, these are standard on all non specialty hid bulbs, in short ballast/canbus to match truck, bulb to fit in light
T
TRIGGER_Hemi
i have the H1 bulbs but i can't figure out how I'm going to run the wires since the lows and highs are connect as on where the bulb wires meet the truck plug.
Am i looking at it all wrong
T
TRIGGER_Hemi
problem is the H11 connector from the truck doesn't fit the harness. in that pic the red and black and blue and black wire go to one plug those are the high and low beams nothing matches those or the one coming from the truck
Reticle918
