2008.5 T style ????I installed the 2008.5 T-style steering upgrade to my 2001 1500 4x4. So now I have the beefier version of 3/4 ton steering. It looks stout and feels smooth as silk.
2008.5 T style ????
Where can I order this from I'm thinking of replacing mine with the T-style.T-style refers to the shape of the linkage (the original was Y-style).
It is an upgraded version of steering linkage that they made for 2500 and 3500 starting mid year in 2008. They recalled the 2003 to early 2008 trucks to install this part. It also happens to be a direct bolt on for any 4wd from 2000 or later.
Well I've been away for awhile. Hardly drive the truck anymore. Slowly been finishing up putting the other engine together. Found a hole in the frame in a section I thought was rust free. Replaced the steering box with a redhead and now my steering is worse than it was before. Redhead told me to change the 1 year old, 3000 miles on it pump and it helped but didn't actually give good steering no matter how much I bleed everything. Kinda hard to stay motivated on the old thing. Still a joy to drive and use and all but just needs so much lol
Knock on wood but I still have yet to have that blend door issue. I DID have an issue where it was sticking and I sent an entire winter without heat because we couldn’t figure it out. I was only 16 at the time and could barely change my own oil. With the truck off you could hear it trying to move if you cycled the heat setting. Did that a couple dozen tones and what do you know suddenly had heat! Too bad it was mid friggin March by the time we found that. That was a damn cold winter that year too. Short winter but so so cold lol.I know the feeling! Don't give up!
Mr Drip has been bleeding power steering fluid out of the pump front seal for a while...marking his turf throughout the Tulsa metropolitan area.
I went down and talked to my mechanic about replacing, actually rebuilding the original part. He went over to one of his work benches, reached to a box on top of a pile of parts and grabbed a small box.
"Try this" he says. It's an ATP product designed to stop leaks n PS pumps, transmissions and other gear boxes.
For a 8oz bottle it sure is heavy. Got some glycol type product in it. I pour it in the pump, filling it, and drove home.
That was 3 weeks ago. Checked the ps fluid today and it's still full. Don't know what's in that magic voodoo stuff but I love it.
Since I stooped the bleeding, Mr Drip decided his A/C should stop working. So I put a dye shot in. No dye and air gets warmer. Thought I overfilled the system, so I bleed it. No worky.
I start hearing strange grinding sounds from under the dash. Come to find the blend door isn't working. That little link between the motor and the door broke! while I hear it's a common problem, mine waited 19 years to become one.
Total pain to remove motor thanks to some moron of an engineer. Couldn't wedge my fat, gimped up old **** up under the dash to get that back screw out. So....I remove the passenger seat...and am painfully reminded that the center console must be removed as well!
Once the interior was cleared I was able to see what I was doing and get the blend motor out. Now it works but I needed more freon. Got a can of voodoo leak stop R 134 and filled it. For now I have cold air. Maybe too much compressor oil, but I got cold air.
Tomorrow I'll deep clean the rubber mat and shampoo the seats.
The convertible lost it's power brake booster and the Charger has a leaking thermostat seal.
![IMG_20200613_082537[1].jpg IMG_20200613_082537[1].jpg](https://www.ramforum.com/data/attachments/201/201014-bb3aa07e134892f2ac44cb502bcf882a.jpg)
