- May 3, 2018
- 2,197
- 3,202
- Location
- North Prince George, VA
- 2017
- 5.7
Now that I got the Keyless Enter & Go working fully, today I reddened up the truck a bit:
Looks pretty good without the black vinyl B-Pillars!
Next on the list (and last thing for a bit) is to install the Putco Blade. Oh, and I need to fuel her up. I think that'll make me fairly done with messing around. For now.
nice, but damn are they expensive!
Well it’s an iPad mini 4.
Reason’s why:
1. Apple car play without wires (can’t do wires and don’t wanna spend $600+ for a radio
2. I only had an RA2 and an RA4/3 is much more expensive
3. I didn’t have to pay fo custom work
4. My phone on my hip automatically transfers calls to iPad
5. $80 gets me a wireless antenna that will put the backup camera on my iPad without moving it. Just touch the app when going in reverse
5. WAZE on a big screen
6. YouTube in truck
7. Email
8. This forum in my truck while waiting for train without taking my phone off my hip
9. Etc etc
I love this. Looks akin to my old Broncos spare carrier. If you get some down time I'd be interested in specs and pics, I will for sure try to replicate this.Finished my not so “classified” project of seeing if it’s possible to build a swing out tire carrier that would work with oem gate and components. Is it possible YES is it a pain in the a$$ also YES.
Ran out of gas and wire on the mig welder so ended up doing about half the welding with the ole tig machine which takes me about 10 times as long to do. But I definitely needed the practice.
The brackets will be the hard part, also had to shim the tailgate over to clear the lower which in turn your tailgate latch will not be happy about.I love this. Looks akin to my old Broncos spare carrier. If you get some down time I'd be interested in specs and pics, I will for sure try to replicate this.
Sent from my P00I using Tapatalk
Has about 1/4” sag from the weight of the tire but the bracket hasn’t made contact with the tailgate yet. If it does i’ll have to come up with some sort of bed stiffenerHow solid is it with the swing gate open, I know that's usually when you can tell how strong the mounting surface is. Pretty decent rigidity?
Wonder if you could make a small "L" bracket from that upper inside bolt to maybe the bedside or something. Maybe even a sandwich plate for good measure. Keep it minimally intrusive for the most part.Has about 1/4” sag from the weight of the tire but the bracket hasn’t made contact with the tailgate yet. If it does i’ll have to come up with some sort of bed stiffener
L bracket may be enough to stabilize it a bit more. I actually bought a T handle spring pin to use as a swing stop but ran out of patience with this project. It’ll eventually get put on just hopefully before it does bite me in the ****.Wonder if you could make a small "L" bracket from that upper inside bolt to maybe the bedside or something. Maybe even a sandwich plate for good measure. Keep it minimally intrusive for the most part.
Are you gonna add a swing stop to keep the tire from accidentally pushing the bed side in, there's always that 1 time the swing gate gets away from you....I lost a window in my xj that way
You spent a lot of time doin those bedsides, that was why I thought of it. Eventually works, eventually ill get a new lead for my not welder and stop being a freaking bum. EventuallyL bracket may be enough to stabilize it a bit more. I actually bought a T handle spring pin to use as a swing stop but ran out of patience with this project. It’ll eventually get put on just hopefully before it does bite me in the ****.
