what do you think?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
those headlights are WAY overpriced. You should be able to get those for less than $100 on eBay day in day out.
Tails are spiffy - match the 3rd though.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
They look great. Talk to Jeremy at Retro Shop before you order those elsewhere though. Some of the aftermarket headlights dont fit correctly, and you will not have that problem with the ones Jeremy sells.
NVM...you beat me to it...haha.
**Word of caution on the ones from ebay...they are hit and miss when it comes to fitment. I bought a set like these for my brothers truck, and the mounting holes arent even close to lining up. When I contacted the seller about it, then told me there is nothing they can do because I had already tried to install them. (How else was I supposed to know they didnt fit besides tryng to install them?). I wish i could remember the sellers name now to make sure you didnt go through them though.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
i kinda thought so myself, basically the same as factory only black on the inside and a clear reflector.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
look the same to me. i clicked on that link, said they wouldnt work on the 1500, i figured it was the same for the 1500 2500 and 3500
reefguy89
laurel de
i got my heads and tails from ebay and have had no problem with them. And they where alot cheaper than the ones you posted.
TexasRammer
College Station, TX
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I've used the ones from "ps team" before. not bad stuff there.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
that auction said:
Relay harness may required if your vehicle doesn't have enough power, the relay harness is not included
This HID kit is single filament only (no HI-Beam)
this isn't a good sign......
Let me rephrase that. These won't work correctly.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
HIDs can come 2 ways. A single bulb (preferred with a small halogen bulb next to it to fool the computer into thinking there is a high beam), or a single bixenon bulb - which moves to give you your high beam.
On our trucks - a vehicle specific wiring harness is needed. Without it, when you start the truck, the HIDs will strobe.
geneseedennis
