Ok so max trailer weight is what it sits at on a scale loaded for camping in the case of a travel trailer.
Not what it could potentially weigh if you maxed out the trailer to its GVWR
Do I understand that correctly now?
GVWR is the rating for the truck and not what it is towing i.e. trucks, fluids, cargo, etc....
It DOES include the tongue weight though....but not the trailer weight.
All of these numbers need to be considered though, as one affects the other, which is why you want to have some wiggle room when determining what truck you need based on the trailer you intend to tow.
Sorry i meant the GVWR of the trailer.
Is Max towing # the weight of a trailer ready for camping. (fluids food etc)
or is max towing # the GVWR of the trailer
I understand the Gross trailer weight. That dry weight plus gear cant be more.
My question is does the truck have to be rated to tow the gross trailer weight. Regardless of the dry weight or dry weight plus gear you put in it. (what it would scale at)
