What gears would I have in a stock 2008 Hemi QC?
FSUNole17
Truck is stock but I am the 3rd owner and don't know how to tell. Truck takes off like a scalded dog though and I love it
suzukiquadrider
cummins 5.9, 6.6 duramax
i would assume 3.55 or 3.92
zack
pa
2004.5 packing the smarty
5.9 cummins ho
there is a tag on the rear look in the door jam or call the dealer with your vin they can tell you
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
Yep like others there could be a stamp on your axle indicating your ratio. You can also give your Dealership the VIN for a build sheet. That will tell you what factory gear ratio it came with and if it has lsd.
Since you are the 3rd owner then who knows if its still factory or aftermarket. If you have lsd/posi then jack the rear on stands and mark the drive shaft and tire. Rotate the tire once and count how many rotations the DS does in that time. That should indicate what ratio you have.
If you have non posi then i think you just jack up one tire.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
bet it's 3.92's...
