I want to say 2 feet or more during flash flood rain. In and out in seconds but it threw the truck pretty good. I was only doing about 20 mph because I was taking a left in 100 ft.
The evap line that is burnt is from the filter on the evap canister. I ordered a new "mushroom" vent cap from dodge. I think the only purpose of that line after my research is to vent the evap system. So even burnt I would assume it could still vent because the mushroom stem, if you will, has 5 blades on it that slip into the hard plastic. So no, I dont think this has anything to do with vacuum. I do see the one going to the solenoid and that looks fine.
I think the water broke the zip ties off the lines and thats what made this line flop down and get burnt.
I did get up on the engine and feel behind the manifold. The PCV elbow seems to be in and it feels decent. I tried to look with my digital inspection camera but it didnt help much. I did hook up a vacuum gauge to the TB and it was a constant 19.5 to 20 inHg.
outside air temp this morning is 63 degrees according to my outdoor thermometer
_________________________________ECT____ MAP ____IAT ___TPS____ RPM
on a cold non running engine __________63 _____29 inHg__ 63____ 11.0 %___ 0
at startup__________________________63 _____14 ______63 _____11.4 ____1525
at engine coolant at approx 200 degrees 194 ______9 ______75 _____11.4 ____1660
the TPS changes when i step on accelerator, live data rpms match dash tach
I do get a P0068 code but I dont think its a true code. I make it happen when I come to a stop and keep the truck in gear as long as possible before having to press in the clutch to avoid the 3000 rpm surge when truck is rolling in neutral. After it comes to a stop it sometimes goes back down to 1500 but other times it remains at 3000.
I was wondering about my O2 sensors as they do seem funky. I know the bank 1's are supposed to fluctuate and the bank 2's are to be somewhat steady.
When I looked the bank 1's do seem to fluctuate, the bank 2's seem to go straight then dip down but this is all at idle. I would need to drive around I think to get a real picture of what is going on. I will do that later today.
Would water in the trans vent effect idle?
