What is this?
FC1ant
alabama
i was digging through the dash to swap my heater only box with a heat/ac unit from a 91. i found a relay? its not on any diagram for my year of truck that i can find. The questions are what is it and do i need it? the truck runs without it. it has only 4 wires and what looks like a battery backup?
4363011
1 1505
emr 7902
crazzywolfie
under the truck
looks like maintenance reminder box. it should hook to the maintenance reminder light
FC1ant
FC1ant
alabama
I don't have a maintenance light. The PO put a gauge kit where the info center would normally be. So it should be safe to remove when I get to rewiring?
crazzywolfie
under the truck
should be fine to remove. the maintenance require light should be in with the gauges. i used it on my 81 as a reminder when my electric fans were on.
jakefrancis127
i like that, you running a single or dual relays to power them?
Joey93
