What is this?...
ZakkBaker
FTW, TX
5.7L HEMI
Taking off my CAI and accidently snapped this tube thing trying to move it out of the way. Didnt realize it was that fragile... When it snapped I heard a release of pressure somewhere, so I'm just guessing it has something to do with the HVAC? -_- I electrical taped it just for now... Could somebody explain to me what it is please? Thanks....
Chewy
Bettendorf IA
V8
lol no that's going into the brake booster so it's probably using some of the vacuum from the line. It's probably for your HVAC unit to control the flappers that direct air up or down.
cpudoc
Its def a Vac line, Maybe to the HVAC system
ZakkBaker
ZakkBaker
FTW, TX
5.7L HEMI
Great....lol. Well at least it's nothing SERIOUS. I also figured it was something to do with the HVAC bc it leads to underneath the dash area. Hope its a simple repair, but doubt it will be. Thanks blackout and Chewy :)
ZakkBaker
ZakkBaker
FTW, TX
5.7L HEMI
alright thx cpudoc. I'm gonna look into it. lol....
jbmobbs
murfreesboro, tennessee
go to the junk yard and cut a piece of vac line off a car and slide it on and get come silicone around the ends of the piece u put on it and itll be sealed.
statmat
2007 Big Horn 4x4
its a vacuum line which would be the reason pressure was released. Just trace it back and see where it ends up at
ZakkBaker
ZakkBaker
FTW, TX
5.7L HEMI
@statman, It just leads to the back of the engine to where I believe is underneath the dash. And I have very little auto experience, so I wouldnt know what it does...lol
HolyRamBatman
Deep in the Heart of Texas
If the pieces will match up, you can put something along the lines of JB weld, gorilla glue, or some other epoxy/sealant.
It has to be sealed on the matching surface and outside surface. You CAN NOT block the inside path.
It also has to be strong or you will be doing this again.
The best way to do it is replace it. Look under the dash on the side where is goes in and see if you find it.
This is where you start learning auto mechanics.
joshhhh
