What kind of 3rd brake light are you running.
mpress2570
Looking to get an LED third brake light for my 17 sport. What do you guys like? Best, brightest, nicest, best looking, whatcha got?
Avgas
2015 Express
3.6 Pentastar
I got a red one
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
I have this on the way...
http://www.ebay.com/itm/361891615708
There's a lot more options from there. Not sure I'll be happy with this one, but it was cheaper to add it in with my new tail lights.. figure I'll try it. Saving critique until I have it in from the of me.
mpress2570
mpress2570
I'm thinking I can just replace the stock bulbs with led bulbs. Any clue? Or is it a sealed unit
nateinva
Central Virginia
5.7L
Not sealed...It's got bulbs. Just confirm whether or not you need resistor. AND, make sure the light has a good seal when you put it back....our trucks are known for leaking here into the headliner.
crazykid1994
I put leds in mine. Look good and no problems.
lonestar21
CA
2019 Ram 1500 Big Horn
It's not a sealed unit at all, it can be done but I don't recommend it due to depending what led bulb you it might give you a brake light out error message.
Your best bet is getting an aftermarket led 3rd brake light that already comes with resistors to avoid any light out messages. The price will be around the same as if you would be buying led bulbs and cargo lights if you want to upgrade that as well.
I got mine on eBay for $40 no problems at all and they look great and bright
mpress2570
mpress2570
Basically every other light is LED on the truck all of the exterior and interior lights are led from the factory except the 3rd brake light and license plate lamps. I already converted the license plate lamps to LED with no resistors or canbus bulbs. Haven't had an issue. I'm assuming I won't need resistors or canbus bulbs for the 3rd brake lamp either. am I right?
mpress2570
mpress2570
It's not a sealed unit at all it can be done but I don't recommend it due to the led bulb giving you a brake light out message.
Your best bet is getting an aftermarket led 3rd brake light that already comes with resistors to avoid any light out messages. The price will be around the same as if you would be buying bulbs. I got mine on eBay for $40 no problems at all and they look great
I didn't know they had a warning message. These should solve that shouldn't they?
clh1220
st Louis
Mine blinks fast like a pulse ,when you first hit the brake pedal. Like ones you see on emergency vehicles.
crazykid1994
Mine are all led that I put in. No problems whatsoever.
mpress2570
mpress2570
How'd you get them to do that? I've seen that on several cars before where they flash like 3-5 times when you first hit the brake
pgr1990
I have a recon on my 2015... it comes with a built in resistor so no error codes or hyperflashing. Works great took me 5 minutes to install.
nateinva
Central Virginia
5.7L
Should be fine....I've recently swapped plate bulbs and fog lights....No resistors.
Resistors mainly needed for reverse lights and aftermarket headlights with DRLs.
mpress2570
mpress2570
These will cancel the bulb out warning correct?
clh1220
st Louis
I honestly don't know how it was done on my truck. The dealer does it to them as part of a dealer prep.
mpress2570
mpress2570
Just ordered 5 of those canbus 921 bulbs for my work lights 3rd brake light and reverse lights. 25 bucks for all 5 not including shipping. They do not cause any warnings. Still thinking about ordering the flashers too.
ChloeBrooks
