What rim for Regular 2020 1500 Spare Tire?
JackLaramie
What Rim fits a Regular 275x65x18 tire to mount under the bed as a spare on a 1500? Where did you get the rim? I need to get rid of the temporary tire.
Thanks for any info...
abnfdc
Granite State
The current spare rim will work, but you'll have to adjust the tire size if your rims are different. Example my spare rim is 18" and my regulars are 20". Use a tire size calculator to get a similar diameter tire in the different rim size.
I found a 20" take off on ebay and will put a normal decent load range tire similar to my others on it.
JayLeonard
6.7 L Cummins
When I had my 17 Bighorn I searched Craigslist and finally found a single rim that was the same as the ones I had. It took a while but I found a single from an oler year truck. I had to modify the spare "T" to fit thru the smaller hole.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
This might not be a good solution as there probably aren't very many people getting rid of 5th gen 1500 wheels yet. 5th gens have 6 lugs, and previous generations of 1500's have 5 lugs. But it's worth a try.
KeithP
Hemi 5.7 VVT
Detroit Wheel & Tire has exact size 18” rims for 2019 through 2021 Rams. They’re a little pricey but they are OEM rims.
turkeybird56
Central Texas
Checked above, $195.00 for factory OEM plus shipping.
MOPAR PARTS SEE ATTACHMENT:rim.JPG
