What size engine do I have?
Andrew Alvarez
Albuquerque, New Mexico
V8
How do I determine what size engine I have? Can it be determined from the VIN? Just picked up my first 1st Gen at an auction so I know zero about the truck other than that the engine seals are leaking. Plan is to have the engine rebuilt right away to avoid future problems.
This is a work truck, but as long as the engine is out what does the group suggest for additional horsepower, ease of use and dependability?
MADDOG
Living in a Firepit
Look for a sticker with emissions information on or near the radiator core support. If it is there it will tell you what size engine you have, either in liters or cubic inches.
Runaround
Silsbee
You can tryWindow StickerLookup Tool website. Nice looking truck.
Runaround
Silsbee
I’m sorry that website is Window Sticker Lookup.com. It will tell you numerous things about your truck.
A
Andrew Alvarez
V8
Thanks for the info. Here are some engine pics for more clues:
I will check the locations mentioned tomorrow. Thanks.
Rlaf75
East Hartford CT
2021 Bighorn
I just noticed you said you were planning on getting the engine rebuilt. Dont know who is going to rebuild it but the engine block should be stamped to identify which motor it is too in case the engine sticker is not under the hood
Usually the cu. in. of the engine on those trucks was either painted or glued on the valve covers or air cleaner
Hopefully the engine has not been rebuilt before & is either a 340 or 360
Wahrsuul
Central S.C.
The stickers aren't always reliable. The one on my brother's 98 said it was a 318 (5.2L), so that's what we bought. Wasn't till we got it out and the replacement in that we found out it was a 360 (5.9L). We trusted the decal, but apparently someone swapped out the rad support at some time.
Daw14
South Florida
Crawl under and look at the block it is cast into it , on the side .I do not recall which.
u2slow
BC, Canada
Cummins 6BTA
Thank you in advance.View attachment 490269
8th digit of the vin indicates the engine. Use www.car-part.com to lookup an engine for your year, and it will give you the list.
Fyi, '1stgen' as far as these trucks go is a reference to the cummins diesel engine... so they're all 89-93 with the 5.9L diesel.
A
Andrew Alvarez
V8
You can put the vin in here, it will tell you what the truck originally came with
Badass!!!!
Thank you, looks like we have a 5.2L V8 OHV 16V : )
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
if its gas, it'll be a 318 or 360. no 340s were put in the trucks that I know of. Casting numbers will be on the driver side of the block. Visually 318 and 360 are nearly identical. best bet as stated, get under the truck and take a look
Churl Quinn
5.2 Magnum
If you plan to drive it regularly and if the front suspension components have not been replaced, you should probably go ahead and replace them. Ball joints, shocks, bushings, and maybe even coil springs. It will make a huge improvement in the way it drives and handles.
Wulf
United States
That will say what engine the factory put in it, but not if someone since then has done an engine swap. The same for that radiator support sticker. Best place if you are unsure would be the castings mentioned before. Still not 100% reliable in the case of a remanned/bored out motor, but it is more likely.
KAKA
