What size wheel spacer?
NUTSHEMI
Long Island NY
Whats the correct wheel spacer size to fit 35's with the factory chrome clads and a 6" lift? I have a set of 35 mud grapplers I am putting on the stock wheels for the winter. I know I'm gonna need a spacer to fit them, just not sure on the correct size. And whats a good place to purchase them? Thanks
quietpeen
2021 TRX
Hellcat
I moved this o the exterior section since its about wheels tires and spacers.
What is the width of the tires. Does the lift manufacture require a certain backspacing?
NUTSHEMI
NUTSHEMI
Long Island NY
They are the stock 20x9. BDS says it fits a 5" backpacing. I rember reading on here that guys ran a spacer, I just can't find it.
quietpeen
2021 TRX
Hellcat
Then you need at least 3/4" which at that point I would go up to a 1.5" spacer that has its own studs
They may make them as small as 1" not sure though
jake09
Guys have ran 1/4" wheel spacers with 12.50s, stock 20s, and 6" lift..the space between the UCA's will vary between lift companies though..You could probably squeeze by with a 1/4" wheel spacer, but a 1.25" or 1.5" wheel adapter will definitely work. Also give you that wider stance.
