What's wrong with my brakes?
massbear
MA
5.7l
2016 Ram 1500, 5.7l. 49,000 miles. Recently I get some mild feedback when braking, especially from higher speeds. A passenger even asked if my brakes were bad. I figured at 49k it was time for from t pads and rotors. I pulled off the wheels - and the rotors are fine, clean and smooth. The pads have a solid 9/16" of material left, nowhere near worn down. I checked the rears - the same. Plenty of life in the pads. Anybody have a thought about what’s going on here? It feels like the brakes are wearing out - but it doesn’t look like they are.
Have you done any really hard stops lately/jumped on the brakes all of a sudden? You may have warped the rotors
Hard braking doesn't warp rotors, even if they start glowing slightly. Maybe while they're hot you shock cool them, possibly.
@massbear most likely you have build up on your rotors from riding the brakes. A lot of people are guilty of this without realizing it. If your not progressively pushing the pedal down the entire time your coming to a stop, you guessed it "riding the brakes".
Braking too lightly causes the pad/rotor surfaces to polish each other which builds more heat. That heat will "bake" the dust/debris to the surface of the rotor when holding the vehicle at a stop. A way to minimize this is once the vehicle is stopped, let off the brakes and roll forward a few feet.
M
massbear
MA
5.7l
They don't vibrate or pulse, i.e., it doesn’t feel like a warped rotor. It feels like they're 'grinding', but just slightly, i.e., not like a pad is worn to metal or even the wear bars. All 4 pads look fine, the rotors are smooth and clean, i.e, no grooves worn in them, doesn’t appear to be anything trapped between the pads and the rotors.. No hard/sudden braking of late, or ever. I don't tow anything, never have. And no, I don't ride the brakes. Never have, never will. (And if I were in that habit, i tend to doubt I'd have made it to 49k miles without having to replace at least the pads.)
tron67j
Maryland
As crash68 said, you can't warp brakes, they need to get over 2,000 degrees for anything like that could happen. Even NASCAR breaks don't reach those temperatures. Grinding could be the small metal tab that starts to make contact when brakes get to a certain point. Take it to a good mechanic.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Check your wheel speed sensors for debris build up or brake dust shields for interference.
WSeanMac
Ontario, Canada
similar, pulsing when stopping. had both front and rears done, parking break replaced. it went away slightly then came back. sometimes it's fine , sometimes it's really bad. no idea what is going on. I drive two other vehicles and don't have this problem and have never had it in any other vehicle (some suggested it's the way I drive but this is the only vehicle this has happened to me on, and only in the last few months)
Mister Luck
WEST COAST
5.7 V8
Had a similar problem from interference to driver side wheel speed sensor’s signal was compromised by a bent dust shield ..
you mentioned inspecting the brake components visually
Check the wheel speed sensor for signal interference , physical damage, disruption or connector contamination.
1999 White C5 Coupe
Have you examined the caliber slides? Are they clean and lubricated with high-quality brake lube?
If not, the brake pads will not move smoothly and can cause a vibration or chatter.
PeteA
Pennsylvania
lift the rear off the ground a spin the wheels and see if you feel a drag or if the wheels feel like they are binding. My emergency brake pad separated from the metal frame and was sitting at the top of the drum which was making a constant drag on the rotor. All good now that I replaced them but be warned they were a huge PIA. Worst drum brake job I've ever experienced.
CanuckRam1313
Ontario Canada
2023 Warlock
Perhaps your brakes need a good bedding in process done?
Not that it's related, but being a 16' (as your sig indicates), perhaps a good time to do a thorough brake fluid flush & fill?
When is the last time you had your brakes (front & rears) fully serviced and lubed?
You sure it isn't the warning clip on the pads?
southalum
