Wheel and tire offset with level
H-fletch94
HEMI 5.7
Hey guys! So at the moment my truck is leveled with bilstein 5100 set at 2.1 and I'm curious as to what's the widest offset I can run with 35s. I've seen countless threads with people able to run 35s with either a -12 or 0 offset wheel with no rub or issues but the wheels I'm looking at are 18x10 with a -24 offset. The truck currently is running stock 20x8s with 285/65r20 nitto terra grappler G2s.
Here is an album of the the truck when I installed my bumper so y'all can get a good idea of what I'm workin with
https://imgur.com/a/dcBwM
I eventually would like to go with a higher lift (which is why I'm trying to fit a wider offset wheel). So should I wait until I save up enough funds for both wheels, tires and lift or is it worth the risk buying the wheels and tires now with my level?
Any help is appreciated! Let me know if there are any problems with the link!
Red5Point7
My truck is leveled with 35s on a 20x9 -12 wheel with zero rubbing
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You can run the 18x10 -24 offset wheels with 35x12.5's but you'll need to bump your Bilsteins up to 2.8" and you'll be trimming some plastic and possibly the pinch weld as well.
H-fletch94
H-fletch94
HEMI 5.7
Damn, I wouldn't mind trimming the plastic but I don't want to mess with the pinch weld. I guess I'll have to wait until the truck is a bit higher, thanks for your input!
H-fletch94
H-fletch94
HEMI 5.7
That -12 doesn't look half bad, what wheels are you running?
Red5Point7
Mayhem tanks, like I said 20x9 -12. Whole set up is for sale [emoji57]
