Wheel bearing/ front brake rotor
That201857guy
Napanee Ontario
Would it be possible to put a wheel bearing of a 2004 ram 2500 on my 1999 Cummins to make it easier to replace the front brake rotors in the future
Runaround
Silsbee
What is hard about the current setup? All you do now is pull the tire/wheel off and the brake caliper. You don’t even have to deal with the bearing.
Dean2
Near Edmonton
You clearly never tried this. If you need to remove, replace or resurface the rotor there is a lot more to it than on a half ton.
OP- the swap you want won't work. I usually get more than 100,000 miles before needing to remove a rotor on 2500 and 3500 trucks and by then the bearings should be repacked, diff oil changed etc anyhow. One tip, make sure you replace the axle seals, don't try to reuse the existing ones.
24vcummins99
Canada
Cummins 5.9
Okay I just got the 99 and putting it on the road front brakes need to be done and know I have to pound the studs out to get the rotor off but thanks for the input
Kamikowski
