wheel spacer size
Hemi Ram12
So a friend of mine has a set of Nitto Terra Grappler G2 LT275 /65 R20 and a set of Nitto Terra Grappler G2 LT285 /65 R20 that he is pulling off his two jeeps and putting mud tires on now and i was wanting to know what size wheel spacer would i need to get either one to work on my 2012 Ram 1500 ST 2wd truck
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You won't need wheel spacers for either one but you will need a leveling kit for the 285/65/20's. The 275/65/20's should just clear at stock height.
AustinB
Banned
San Diego, Left Coast
I can tell you from experience that the 275/65/20 WILL fit at stock height and no spacer.
H
Hemi Ram12
okay that sounds good to me and worse case i just hold on to the tires until i get the leveling kit or a lift kit then and thanks for the help
xrsman
Ontario
3.0 Ecodiesel
The 275/65/20 is only 1" larger in diameter than your stock tires. They'll fit no problem!
Sent from my SM-G920W8 using Tapatalk
Cyborg2337
South Jersey
Both should fit with no spacers needed. The 285's are 34.57" tall, 11.5" wide so a level will probably be needed for these just for aesthetics alone. Both will LOOK the best with a level.
