Wheel spacers; go flush or wide?
muddy12
Indiana
So, I've got a 2012, 1500, 4x4. It has a 6" lift, and 35x12.50's on the stock rims. I just rotated my new tires, and discovered that the previous owner put some cheap .25"spacers on the front. I had a shop put on the new tires, and they said nothing about the spacers. Anyway, I believe they are the cause of a slight vibration that I'm getting in the front end at higher speeds.
I can't afford new rims at the moment, so I'm going to go with some quality hub-centric spacers. My question is regarding the width. If I use 1.5" spacers, the rear tires will be flush with the flares, and the fronts will stick out just a bit. If I go with 2" spacers, the tires will be out past the flares about 1" in the front and about 1/2" in the rear.
So, flush the tires, or poke them out?
quietpeen
2021 TRX
Hellcat
all depends on what look you like. Them poking out will give a little more aggressive look
Jershipe
Monroe Michigan
I like them poked out. I ran 1 1/2 bora spacers. Didn't have to trim the studs. There was pockets in rim . Plenty of clearance for the little amount the studs stuck out. That was with express 20's.
911ems
Toledo OH
I went with 2" and I love them. I went back and forth on the idea too, and I'm glad I went with 2"
xrsman
Ontario
3.0 Ecodiesel
I had stock flares on my 2014. With 35's and 1.5" spacers, the tires still stuck out an inch or more past the flares. It looked awesome. My gravel road in the spring hated it though! Lol
Sent from my SM-G950W using Tapatalk
muddy12
muddy12
Indiana
I decided to go with the 2" spacers. They should be here middle of next week. I'll post pics when they are installed. They should push the rear tires about 1/2" past the flares, and about 1" past in the front.
I also live on gravel, I may have to look into some mud flaps, or possibly bed lining the rocker area.
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Poke em out...I went with 1.5" spacers and wish I'd done 2"...
muddy12
muddy12
Indiana
Spacers were finally delivered yesterday. According to FedEx tracking, they had been sitting in a distribution hub 80 miles from my house for the last 3 days.
Anyway, I only had time to open the packaging and snap a few pics. If the weather cooperates, I'll get them installed this weekend.
4ab4375f2be78fecd38577731631270d.jpg4af86ee38998cc92c96df9fef1f3ffc7.jpg0d335c91afd1ab12a7ee38fc88b4527c.jpg
muddy12
muddy12
Indiana
Got the spacers installed. 2" didn't push the tires out quite as much as I thought it would, but I'm happy with the result.
I think if it weren't for the flares, the difference would be much more noticeable.
muddy12
muddy12
Indiana
The big advantage though, is the added clearance between the knuckle and tire. Here's before, with the 1/4" spacers.
And here's with the 2" spacer.
Rzrman328
The treeline
Ya the flares really hide the poke. Trust me, they're out there.
02ramboi
live oak florida
4.7 v8
I have 1.5 on the oem 20's and I didn't have to cut or trim any mugs.
muddy12
muddy12
Indiana
It looked like I could have fit 1.5" without any cutting, but I'm glad I went with the 2". Tires are just slightly past the flares, but not so far that they throw a lot of stuff on the body. As an added bonus, I can now turn lock to lock without rubbing on the sway bar ends.
jtecodiesel
Newfoundland
3.0L Ecodiesel
Again didn't know what I was doing and posted nothing. :)
jtecodiesel
Newfoundland
3.0L Ecodiesel
xrsman, I am looking for 1.5" spacers for my 2014 ecodiesel and wondering which brand/where you got yours? I'm hoping the 1.5" will not require replacing existing studs. Maybe just a slight grinding. Plus it looks like the spacer studs are nice and long as I would like mine to be around 1.5". Thanks in advance.
Hey I just figured out how to find stuff on the forum and found the threads on Bora spacers. You'll have to forgive the newb!
ameer73
