Wheel studs
Tsnyder527
Ohio
Not sure iF this is the correct spot for this post, but...
I found out the hard way that the lug threads changed from the 03 to 15 ram. I swapped out my aftermarket wheels and lug nuts, about time to rotate my tires and I am assuming the studs and/or bolts are going to be stripped out, so I am planning on buying both and replacing them.. can anyone tell me with the wheel studs are the same for the front and rear? I can only seem to find them for the rear.
Thanks in advance!
joshhhh
