Wheel/Tire help...
jwilkinson79
West Islip, New York 11795
Ok, so I want to go from a 20" to a 17" and run a 315/70/17 BFG KO2, trying to figure of what offset/back spacing I'm needing here, it's driving me nuts. Truck is leveled at 2.1, if needed I can go to 2.8 and add a rear spacer just not sure what size. Any help is appreciated.
quietpeen
2021 TRX
Hellcat
How wide of whee,l and are your looking for them to stick out a lot or a little
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
0 offset to -12 0ffset on a 17x9 rim which should put you at 5" to 4.53" back spacing.
From I have found stock 17s are like 5.75 bs so you need to have 5.5" or more bs to clear the upper a-arms.
quietpeen
2021 TRX
Hellcat
0 offset to -12 0ffset on a 17x9 rim which should put you at 5.5 to 4.53" back spacing.
Zero offset on a 9" wheel is 5" backspacing
Less backspacing clears the control arm more
quietpeen
2021 TRX
Hellcat
Get 17x9 zero offset
quietpeen
2021 TRX
Hellcat
With that diameter tire and wheel offset you should be fine. If you have any rubbing It would be minimal
Raadz
