Wheel to Wheel steps?
ChadinTexas
US
5.7 VVTI
Does anyone have experience with a wheel to wheel sidestep or running boards? I have a 2021 Laramie, Crew Cab 5.7" bed.
Preferably non-drill mounting. Thanks!
Sent from my SM-G988U using Tapatalk
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
White knuckle off road rock sliders mount to the frame and look freakin sweet. Not cheap though.
Papa Red
Papa Red
Nebo, NC.
I have the factory wheel to wheel side steps and love them. Strong and at a perfect height for my truck.
Red
BOWERSFJ
Uniontown OH
I had N-Fab, and hated them .... Found a set of OEM new in the box on Ebay, and they are so much better
2016Bighorny
Wisconsin
I have the Mopar OEM wheel-to-wheel steps on my 16 Crew Cab, and at a svelte 323lbs and 6'4" tall, they NEVER feel unstable under my feet at all!!
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Mega Steps for mine and I couldn’t be happier. They have brackets that bolt to the same place as the factory steps and even include a fourth set of brackets that go on the rear ends of the steps in front of the back tires for extra support that use factory holes on the lower front track bar attachments. They weren’t cheap at just under a grand but they’re really sturdy, well built steps.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I also have the OEM Wheel to Wheel . Love them and they are holding up in Maine winters . No drilling required mounting hole there from factory
GunnyJC
Milwaukee, WI
2021 Ram 1500 Crew Cab Laramie 4x4
Hemi 5.7 eTorque
I went with the Mopar wheel to wheels. As someone mentioned earlier, a bit spongy near rear wheel. I'm 6x3" and about 205.20201220_112639_1.jpg
corneileous
Podunkyville, OK
I went with the Mopar wheel to wheels. As someone mentioned earlier, a bit spongy near rear wheel. I'm 6x3" and about 205.View attachment 234201
I’m just curious but since the painted to match boards that my truck came with brand new don’t actually go from
wheel to wheel like those chrome ones look like they do, there’s just only three brackets that bolt to the bottom of my cab and that pinch weld all the way down at the bottom; did Ram use any kind of a fourth bracket back there by the rear wheels or did they just rely on the same three brackets mine came with?
As I mentioned earlier, since my new Laverne steps go all the way from
wheel to wheel, they actually came with a two-piece fourth bracket that attaches to a factory hole the front suspension piece where the front of the lower front control arms connect to.
GunnyJC
Milwaukee, WI
Hemi 5.7 eTorque
I think one of the reasons for the spongy feeling in the rear is that the Mopar w-t-w ones that I have only have two mounting places. If you blow up the picture you can see one under where the word RAM is on the front quarter panel and the other is below the rear end of the rear door.
corneileous
Podunkyville, OK
That must be somethin’ new on the 5th gens then because the 4th gens use three mounting brackets per side.
Festus
South Carolina
2020 Tradesman
6.7L diesel
Hi
I have a 2020 2500HD Crew Cab 4x4 Diesel Tradesman. I installed the Raptor Series cab length running boards. Totally satisfied with the brand, looks, and strength.
Festus
Warmachine1320
Sparta, NJ
5.7 8spd
ill second that the white knuckle sliders are great, sit tight to the body but still useable even for my big clodhoppers in steeltoes, and frame mounted no drill install, plus if you ever offroad em they are a fantastic slider
Fergusontd
FTD
Villanova
These are the ones I had installed when I bought it new! Works great so far!
