Where Did This Plastic Cap Come From?
BigRed17
Nova Scotia
Cummins 6.7
Hi all, I found this blue soft plastic (flexible) cap near the rear differential of my 2017 Ram 2500 with the Cummins engine. It's about 1-1/4 inches long. Does anyone know where it could have fallen from? Cheers.
TJP440
omaha
hemi
looks like a generic plastic cap that is used on a lot of things. Never seen one n that color though? Is it the same color as your truck?
B
BigRed17
Nova Scotia
Cummins 6.7
Thanks for the reply. No, the truck is red. I know that the cap is some kind of connector cap or fluid line cap, or similar, but I'm hoping to find out specifically what it's for. I crawled around the underside of the truck for about 15 minutes but couldn't see anything.
Cap looks to clean and new to have come off a 8 year old Nova Scotia truck,i'd hazard a guess it's from something else
David H
USA RET
Minneapolis
Looks like a bullet connector sleeve. Is there a hole in the skinny end?
Something like this.
Dredger
SE Ohio
That's a vinyl pull-tab cap. Those things have numerous applications. Impossible for us to say where it came from.
B
BigRed17
Nova Scotia
Cummins 6.7
These are helpful replies, thanks! I had to clean up the cap to make it look so good. It was covered in grime and I thought it was black at first. It's definitely from my truck, as it is parked in one spot only and that is where I found the cap.
Marshall
Sk, Canada
2014 sport
Just add to the I will need that in 15 ys box. ( it looks handy)
I get a lot of "wth do you want that for? " that for at home.
Starting a new pile for the G. grandkids x3 now
MADDOG
Living in a Firepit
Check to see if your differential vent has a cap on it.
RamInfo
Utah
5.7L HEMI
I think post #9 has the answer, and the cap you found has been lurking atop the fuel tank, or stuck in a corner of the frame rail, etc. for all these years and finally worked its way to an escape point. Add it to the grandkid’s pile and take them out for an ice cream cone.
Best,
RI
