which engine should i be on the lookout for
WildcatHemi
Kingwood, Texas
im looking at early Ram trucks. im seeing them with slant 6, 318? and 360’s. pretty sure i dont need a 360 but if its the better option i will consider.
truck will just be a cruiser. not a racer or hauler though i may use it to tow the 17’ boat occasionally.
any other advice for looking at older trucks?
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
The 318 is a well-respected and long-lived basic. You can’t go wrong with that engine.
The slant six will be underpowered for towing……but just for running around town….I wouldn’t turn it down.
WildcatHemi
WildcatHemi
Kingwood, Texas
im also looking at f100’s with the 4.9 i6. really rather have a ram though.
huntergreen
Marine Corps Navy Badge
Fords Venturi carbs were a pain in the butt ! That’s my experience.
The slant six is a legend for reliability, but IMHO the 318 would be the engine of choice for your needs.
u2slow
BC, Canada
Cummins 6BTA
I like that engine, but I'm not a fan of the 80's Ford suspensions.
2wd or 4wd? I've always preferred to start at 3/4ton.
Dean2
Near Edmonton
I had them with 318s and a couple of 360s. The 360 was MUCH harder on fuel and produced very little more power than the 318 properly set up. The 360s also wore valves and guides much sooner than the 318s. I would go with the 318, they are easy to get more power out of cheaply.
u2slow
BC, Canada
Cummins 6BTA
Have not experienced the 318/360 economy myself, but have heard about the thirsty 360 from others. Wondered if it's axle ratio related - 318s going in half tons (3.21/3.54) vs opening the door to 4.10 in a 3/4ton.
89-90 model years have been the cheapest finds for me. The old-school crowd avoids them because they are EFI. And they also don't have the updated 91-93 nose than some folks love (and possible magnum engines).
David Vandercook
Under the truck
As far as fuel economy goes, I get the exact same between my half ton 2wd with 360 and 3/4 ton 4x4 with 318. If I baby them I can get 12-14 mpg, if I drive hard I can get 7. Usually average about 10 on both though.
Sandevino
North Texas
HEMI 5.7 eTorque
I had a '96 1500 extended cab 4x4 and no matter how I drove it, I got 250 miles per tank. I loved that truck and engine as it's door stop reliable and simple to work on. I bought it used for $2k in 2008 with 100k on the clock and sold it at 250k for $6k.
rvance
Pent 3.6
I've had a couple of 318s, a couple of 360s,and a Slant 6. All good engines. The Slant 6 will go more miles than the V8s. I did have a LOT of trouble with the 2bbl carbs on all 4 V8s. You can probably by a dependable replacement carb these days. The 225 6 can tow a reasonable sized boat pretty well as they are usually geared very low. I used to pull my 16' SeaRay 90mph with my 4 cylinder, 96hp Isuzu Trooper.
shockit
fl
98 Dodge Ram 3500
5.9 cumm
5.9l 98 have 400,000 still new
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
My 98 sport had a 318..maybe 160k...I guess the engine was ok(normal fix it stuff)235 hp i believe..not enough....rest of the truck not so good for me...2 torque converters,then a full tranny rebuild,rear end howled like all he// but never let go,had it checked at 3 places over time..each time each said all looked good(obvious something was amiss),dash cracked everywhere,cup holder couldn't hold a cup,seat cables/webbing(whatever you call it)snapped with me driving down the road...felt like i was sittin on the floor...bunch of little things...if i were to have one again it would have to be mint and very cheap.
From my understanding slant 6 was like bullet proof from the ole timers around me..i don't know though...360 ..ya..couldn't really drive past a gas station.318,360 i know from experience...not a slant 6...my mom had something way back when I was little but no clue.
Wait!!!..it was a rambler..did that have a slant 6?
Hagar1
Ontario Canada
2012 Ram 1500
Yes, the 360 is a thirsty beast.
huntergreen
Nope ! Ramblers had a straight six. Chrysler had the slant six. Is it possible your mother had the Plymouth Valient ? They kind of resembled the ramblers ?
southalum
