which Pro Comp Suspension lift kit?
Ramhergood
Hi
I'm new to lift kits and need some help with what to get.
I've been looking at Pro Comp 6" Suspension lift kits in the $1400-$1800 range but there are so many I'm not sure which one I should get . Any advice would be great. I have a 08 Ram 1500 big horn 5.7 4x4. Also is there anything else I need to buy with one of these kits other then wheels/tires. Thanks
Knotts89
Montvale, Va
U will need new wheels and a rear transmission seal. Also transfer case fluid. I just put a 6 inch pro comp lift on my 08 1500
R
Ramhergood
How do you like it? Did you install it? How many hours to install? I just want an idea of the cost for labor to get it installed ? Thanks
Knotts89
Montvale, Va
Me and a buddy installed it. The kit was really nice it came with new brake lines and everything. It took some time to get it installed. Quite a bit more than the 8 to 10 hours the instructions called for.
