Which transmission do I have?
Jm7106
Georgia
I recently bought a 2014 ram 1500 that needs a transmission. The truck still runs and drives, just not well. I’ve been looking at different options for transmissions, and was looking at rebuild parts for mine, but a lot of the times websites want to know if I have the 845RE or the 8HP70. The truck is a 2014 5.7 Hemi with the 8 speed transmission, 3.21 axle ratio. I’ve managed to find all that but I don’t know how to tell which of those other 2 options I have. Any help?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
use this site, it will have the transmission listed
use capital letters
more detailed information
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
or call the dealer and give them your vin and ask if they could tell you what opinions the truck has and trans is in it
J
Jm7106
Georgia
I forgot to include that the truck is 4x4, but it does appear to be the 8HP70, going by that website GTyankee mentioned, which is also what HuskerRam said. That helps a lot.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
The 5.7 Hemi 2014 Ram 1500 could have either the 65RFE or the 8HP70.
If the shifter is on the steering column its the 6-speed.......if shifter is a dial on the dash its a 8-speed.
If it really is a 3.21 gear it's probably the 8.........most of the 6 trans came with 3.55
It's very easy to tell by the shifter location though unless they did the 8HP70 swap which is quite expensive.
J
Jm7106
Georgia
The shifter is on the dash, it was the rotary/dial shifter. And I crawled under the truck and it has a 3.21 sticker on it so that’s how I found that part out.
