Whipple Supercharger and eTorque
Tach_tech
5.7L HEMI
Yes. I don't think I've seen a single install that tested under 500 at the wheels.
Neither do I. Not sure what he’s talking about embarrassing drivetrain loss. It’s 20-25% on the trucks which is pretty much the standard drivetrain loss for a 4wd truck.
The drivetrain loss would have to be like 30-40% to only make 400 at the wheels with a whipple.
1morepart
2019 Ram 1500 Quad Cab Hemi 3.92’s
Georgia
This is from Whipple’s site. It’s close to 500. Realistically, 470 whp on a “400” bhp motor.
1morepart
Georgia
170 hp gain on a 310 rwhp motor. My only point is you almost lose 100 hp through the drive train.
1morepart
Georgia
Not hating on the Ram. I love both of mine. It’s what you are after. More power for racing or just because.
Tach_tech
5.7L HEMI
Both me and my buddies truck which are identical both have the whipple kit. They made almost identical numbers on the dyno at 505whp. ScLeCo on here made just over 500 at the wheels with his too.
A 100hp loss through drivetrain when the engine is making around 600 at the crank isn’t excessive or embarrassing.
The 20-25% loss is pretty much standard across the board especially for a 4wd truck. So there’s nothing special that makes the Ram/Hemi have any more drivetrain loss than anything comparable.
1morepart
Georgia
I agree with the percentage loss with 4wd but mine is 2wd with almost identical loss. I still plan on putting the 2.9 whipple on my 2020 just like my other Ram I posted. I digress with my embarrassing comment. I would just like to see a far more efficient transmission and drivetrain that has minimal loss. 10-15% tops.
Tach_tech
5.7L HEMI
The 8 speed is quite efficient it’s just everything that adds up and sucks a lot of power. Tranny, t-case, read end. The wheels and tires aren’t very light either so they contribute to it as well.
I agree though, it would be great to see only a 10-15% loss but I have my doubts thats on a happen any time soon. There’s a fine line between making everything extremely efficient but also durable as well.
1morepart
Georgia
Agreed
Coop1984
5.7 hemi etorque
I know this is a older post but just to let everyone know I called whipple today (3/3/2022). They are working on a whipple blower for the 5.7 hemi etorque! Guy said they have a truck on the lift as of today doing test fitting, etc. Kit should be ready by end of 2023 maybe early/mud 2024 at the latest. If you call whipple ask fir Dennis or Dennison. He confirmed it.
Coop1984
5.7 hemi etorque
Edit 3/3/23 not 3/3/22 lol
I thought i read somewhere that the ProCharger blower would work with the e-torque
Coop1984
5.7 hemi etorque
Procharger already has a centrifugal blower for the hemi etorques. Whipple is working on a positive displacement (twin screw or roots style) top mounted blower. Instant torque /power with the whipple vs the linear power progression with the procharger.
Coop1984
5.7 hemi etorque
Give whipple a call for more info.
Hang around awhile,i think you'll find alot of us already know the differances between a postive displacement blower and a progressive blower. I was running nitrous fed turbo set-ups and 6-71 blowers on street cars way back in the early 80's.You're a bit late to the party,i already posted a link to the new whipple awhile ago.
Taking Orders: The 2019-2022 Dodge Ram Whipple Supercharger System is here!!
• The 3.0L Gen 5 Twin-Screw Whipple Supercharger significantly outperforms the competition with 40-50% more power right out of the box (based on 7psi of boost on 91 octane)!
• Billet fuel rails included
• System fits with no cutting
• 8-12 hour install time
• HP Tuner RTD tool included w/ 6 credits
• PCM and TCM modification
• HP Tuner gateway bypass included
• Dodge Hellcat Bosch fuel injectors, 57lb/hr
• Adjustable idler pulley included
• 3-bar Hellcat TRX TMAP sensor
For more details, Visit https://bit.ly/3JTyqle .
Good news, the 2011-2014 & 2015-2018 are coming up next AND we will be releasing the 2023 & E-Torque models soon after. #WhippleFTW #Boost #WhippleSuperchargers
Dan Topp
Jefferson Wisconsin
I almost did the edelbrock setup but was talked out of it for Procharger on my vette since then I went with it for my ram,no issues until you’ve in the 14+ range then a dedicated belt is needed.But good luck don’t know if all the tales of heat soak are true IATs are the enemy.0719F5D3-05CD-42C5-9A28-2AF48263DAE8.jpegB52FA39A-8DDD-4690-8538-30DB8342B9BB.jpeg40584268-730C-4B6D-85EC-F9DCB6940493.jpegD90DE339-1C27-4DB6-A1F9-4AEC1195819A.jpeg
Dan Topp
Jefferson Wisconsin
How much boost can these engines take? Anybody know?
Sent from my SM-N950U using Tapatalk
7-8 lbs. Trans will be the weakest link but if you go beyond the canned Diablo tune Procharger includes with it’s kit.The trans does its torque induced downshifting which makes a dyno tune rough but it can be done with HP and a trans tune.
