White Residue on Black Plastic
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
When I brought my new Ram home in 2014. I was on vacation at the time. I gave her a good bath and pulled her into the garage and closed the door. The next morning I woke up and began applying Chemical Guys Butter Wax to her paint. 1 coat led to 2 and 2 led to 4 coats of warm wax to her paint.
Well after a bit I noticed I was a bit sloppy in some places especially on the bottom edges of the plastic bed rail protectors. I have tryed every thing I can find to remove the white residue left over from the wax. Nothing works.
There are also some small spots through out the truck that the black plastic is cursed with white wax residue. Really looks like a Retard waxed the truck {I am now believing there actually was}.
My questions I guess are these-->Is there any actual products sold that will remove this white residue?
Also is there a wax on the market now that does not leave this white residue?
If not I will in the future just keep a good 1/2" away from all the plastic in future waxing adventures.
Thanks Fellas!
joeygster
Ancaster, Ontario
SyN
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Thank You! I will give them a look.
smoothee
St. John's, NL
After seeing it suggested on here, Dawn dishsoap did the trick for me. Use a small brush and put some elbow grease into it.
SyN
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Peanut butter
Did this with an old toothbrush. Seemed to work until the oil residue dried and most of the white residue just appeared back.
SyN
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
If the eraser does not work I will try this with the tooth brush.
After this issue is dealt with, I will begin the search for a wax that does not create this.
Looking now at the CG Black Light then Jeatseal 109. Then in between using their Hybrid V7 high gloss sealant in between for quick protection.
Hemi_1340R
Indiana
I use collinite 845 and it doesn't leave anything on the trim pieces
joeygster
Ancaster, Ontario
I think that the texture of the trim is the key with Collinite 845. Some people have no issues while others report the chalky residue.
Collinite 845 on trim
Collinite does not recommend the use of any of its product on rubber or black plastic trim...probably because of the mixed results.
FAQs » Collinite
Reactions: SyN
Hemi395
Cape Cod MA
You can use Mothers Back to Black on it and it will remove some of the white residue and make the plastic shine.
What I use is Protectall near any black plastic. You can get it on just about anything on your vehicle and it won't leave a white residue. My truck being black, white residue on the black plastic looks awful! So what I usually do is keep wax about 1-2in away from any black plastic and then use Protectall up to the plastic. Then I finish the plastic off with back to black. Been working great for me so far...
SyN
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Thanks! I will look into all the products. I will agree. I will attempt to keep a slight gab between the wax and plastic from now on. A all black truck with white powdery residue on the plastic trim just looks like Chit! The only place I seemed to acquire this residue was on the bed rail covers. The pencil eraser did a great job.
Thanks to All!
jusalt
hemi
One way to avoid the residue with any wax would be to use a solvent/silcone based dressing on the plastic before waxing. That way if you get any wax on there you will be able to wash it right off without the white stuff. I would recommend AutoMagic magic Dressing. It is easy to apply and lasts a long time, plus you will be able to wax your entire truck. I hope this info helped.
-B-
Northshore of Boston
I use a product from my cycling mechanics background called White Lightning Clean streak , it is a metal prep that is plastic safe there are lots of more sensitive plastic and Cf in cycling than there are in automotive, also good for brake dust and rotor cleaning , deal cal residue, etc
carl0
Hemi 6.1
Try Megs Ultimate Quik Wax. It will not leave any white residue on plastic trims.
SyN
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
Thanks again fellas for all your replies!
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Mask the plastic parts before you wax. One row of tape should do it.
Jay
Lowrider357
