Who has installed AFter Market Grill
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Looking at the after market Grills that are around 200$ or less ! Longhorn/Pig nose style ! I notice they do not have the air diverter things ! Did you notice slightly lower temps or no change ?
How do you like those 165/200$ grills ?? They hold up well ?
Thanks
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Thanks , and thanks for link Did you notice any temperature difference ??? And that is the grill I am looking at ! BUT in Chrome ! I have seen them on E Bay from $165.00 to $200.00 way better then the $600 + for OEM
Temps all seem to be about the same.
M² Mods.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks
joshuaeb09
Medina County, TX
I have this one in black. One of the LEDs started to flicker. They sent me a replacement and it didn't work at all. I like the grille though and it keeps my truck a couple degrees cooler than the stock big horn grille did.
https://www.amazon.com/EAG-Replacem...+1500+grille&qid=1564418442&s=gateway&sr=8-26
I've got the same one, but sold under a different brand on fleabay also in matte black. Did drop the temps on my Hemi compared to the Big Horn/Lonestar grille a bit with the 180 T-Stat/V6 eFan swap. I was already fully AGS deleted so the air flow is a bit better if one has one of the more restrictive grilles. Haven't had any issues with the LED's yet, but I did compare them to some other lights that I have access to and they should fit as replacements. Here's an amazon listing for some cheapo's that should fit.
https://www.amazon.com/dp/B07MVBCQNL/ref=cm_sw_em_r_mt_dp_U_YqdqDbD0611RX
Anzio also has some smoked ones I might try if mine die out for a stealthier look behind my grille guard.
https://www.amazon.com/dp/B07P45P2X4/ref=cm_sw_em_r_mt_dp_U_-rdqDbRPRJXRE
BrewCrew
Lake Arrowhead
HEMI 5.7L
I too have the same one. Love it! I do get some "Looks like a Ford" jokes sometimes....
My temps are all about the same TBH.
