Why are 2500 6.4’s not selling?
Scottly
Safety Harbor, FL
HO 6.7 Cummins
They've focus grouped a turbo 6 in the 2500s to see if current 3/4 ton owners, of both their product and competitors, would be willing to consider it.
They can focus on deeez nuts... Inline 6 for cars? BMW builds great ones. For trucks? Focus...
2003F350
6.7 CTD
Ford's old straight 6 and Jeep's inline 6 would take exception to it. And they take to power adders pretty well, and get up to speed pretty decently.
I think a twin turbo straight 6 would do wonderfully well in the HD truck platform, especially if it's geared right. That 8-speed would probably do just fine.
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I don't disagree, but the old Ford 300, a torque monster in it's own right, was 4.9 liters...The Jeep was a 4.2... 3.0 rung out to produce high numbers just doesn't sound like an engine with a long life span. I'm sure it'll make it to the end of the warranty, though....
Dusty
Rochester, New York
Although this is not relevant to HD trucks, in the half-ton segment Ram increased their Fuel Economy & Greenhouse Gas Rating from a 4 to a 5, and Smog Rating from a 5 to a 6 with the Hurricane. Reducing the displacement and adding forced induction and direct injection, this follows many other manufacturers (especially Ford and Europeans) methods to decrease fuel consumption and maintain market acceptable power levels.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 117667 miles.
Units
Ms
2023 Bighorn
6.7l Cummins
... because they've done nothing but change the headlights, grille, and taillights in the LAST TEN YEARS! ok... the tranny upgrade was nice, but still... hard to justify spending $30-60k for something that looks exactly the same as what you have... in my case anyways.
I think ALOT of the redesigns nowadays are butt ugly. RAM has a very good looking design. If it ain’t broke don’t fix it.
Docwagon1776
Midwest
I dunno. Like others have said, there have been a lot of really solid I6 over the years. Pros and cons like everything.
Personally, I don't trust Stellantis to get it right out of the gate. Not enough trust to buy one, at least. That said, building a motor from scratch with the intent for it to be boosted is going to be significantly better for durability and longevity vs slapping FI on an existing motor. I do like they are using an electric water pump to push coolant to the turbos, even if the motor is off, and not relying on just oil cooling. Modern synthetics don't coke like the old mineral oils did.
I'm willing to be won over, I suppose, but I think I'll be in my 6.4L truck for a very long time. Maybe until I'm in the ground.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Regards,
Dusty
While fine for passenger vehicles and light duty trucks, I just don't feel they are cut out for heavy duty trucks, 3/4 and 1 ton. Not at 3.0L of displacement.
2003F350
6.7 CTD
They will probably up the displacement a bit for HD trucks. It wouldn't surprise me in the least. By how much? I don't know. Enough to get the HP up over 350 without adding a lot of boost pressure.
Fatbob Frank
Mc Gregor, Iowa
6.4L
You're probably right...
But it seems like no one, not just auto manufacturers, are building anything with longevity in mind anymore...
Riccochet
I'm thinking it'll have to be big enough to put out 425-450 HP and 450-500 ft/lbs at low boost pressure to convince buyers away from, and be competitive against, the Ford 7.3 and GM 6.6.
TFL has already shown the little 3.0 TT-I6 to have cooling issues when being worked hard with just 8000 lbs behind it. No way that engine could be in front of 12,000 - 15,000 lbs and not have issues sooner.
The whole reason for large displacement is so the engine isn't really working hard in those situations.
2003F350
6.7 CTD
Yeah, smaller (compact) engines tend to have issues with cooling at higher power outputs anyway, there's just not enough material there to dissipate the heat when you try to make them compact. They'll at least have to increase the physical size to give that heat somewhere to go, along with giving it the ability to withstand higher combustion pressures.
That was a major downfall to the 6.2 diesel GM tried out back in the 80's - there wasn't enough material in the block, and the cylinder walls tended to crack, the mains tended to break, etc. etc. and it was naturally aspirated. If they'd tried to boost it it would have never held up at all.
Docwagon1776
Midwest
QC issues in block casting was a big issue. If you got "a good one" and took care of it, 300k before a rebuild was pretty doable. Assuming you had a lot of patience because they were slooooooooooow. I wanted a flare side one real bad...until I test drove it and realized you could take a nap while during a 0-60 romp.
turkeybird56
Central Texas
I'm amazed at the people who want to sign off their lives on a big full size truck anymore. I have a 2007 Ram 2500 Cummins with 123K. It's going up for sale soon.
You not need yer Cummins anymore? Man, I would keep that puppy forever, because if U come back with the need, anything U get now, tho more tech, not be as reliable as that 2007, just saying.
turkeybird56
Central Texas
What is the saying, Displacement not Replacement, lol.
Dusty
Rochester, New York
I think its, "No replacement for displacement," at least that's the way I've always heard it.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 117717 miles.
turkeybird56
Central Texas
Regards,
Dusty
YEAH, that saying has been manipulated all the time, but the jest is: Smaller motor not gonna be able to do in long run wat a bigger motor will. I'll stick with my poor miserly lil 2019 V8 Hemi VVT with the whopping 395 HP, works for dis BOIRD.
