Why Is My Remote Start Not Activating Heated Seats/ Steering Wheel?
Goose55
Ajo, AZ
Cummins High Output 6.7L
It's not often needed here in Southern Arizona but we can have some chilly mornings. When I first bought my truck new 4 years ago, remote start would always activate the heated seats and steering wheel, but no longer. What could be wrong? Last year they had to put in a entire whole new radio, and 12 inch screen because the heated seats were coming on even when it was 70 degrees. Now, this.
Billet Bee
South Dakota
Cummins 6.7 HOHD
Following
Im in n. Arizona and mine only works on a cool morning maybe 20% of the time. When I say cool, its not really bad but I'm assuming anything below 50* would kick on the preset warming functions with auto start.
turkeybird56
Central Texas
Following
40 F is the setting for Heated Seats and Steering Wheel. Enabled in your U Connect. You need to go into U Connect in sub menu's and confirm that are set to come on, and not disabled.
Administrator
The vehicle outside temperature sensor has to read below 40°F for the heated seats/wheel to auto turn on.
There's options in the radio for the Auto-On, when remote started, every start, or not at all
What temperature do heated seats come on with remote start?
The Remote Starting System also activates the Climate Control, vented seats (if equipped) in temperatures above 80°F (26.7°C), and the heated seats (if equipped), and heated steering wheel (if equipped) in temperatures below 40°F (4.4°C).
OC455
Central NY
^^^THIS^^^
Goose55
Goose55
Ajo, AZ
^^^THIS^^^
Is it easy to find those options in the radio?
OC455
Central NY
Standby, Ill get some pics, your screen and my screen should be the same and the settings should be.....
OC455
Central NY
Start here, find the "settings" icon at the top right corner.
Push the "settings" icon and it will take you to the next screen.
It will show this screen, scroll down to the next page.
OC455
Central NY
The next page will show "Auto-On Comfort & Remote Start" Press that button.
Press the down button and it will open that screen.
That's the settings. The temperatures are set by the factory unless there is a way to change them using AlfaOBD, that's all the end user can do.
I
Goose55
Goose55
Ajo, AZ
Thank you! I'll try and work that out.
2003F350
6.7 CTD
Yes, 45 degrees
As you were informed, it's got to reach 40 for them to kick on. You aren't there yet.
But it's nice to know exactly where that is - I was wondering where that point was, because back in the fall some mornings they'd kick on and others they would not.
turkeybird56
Central Texas
Yes What OC45 showed U was on 12 inch screen. If U have 8.4, and cannot find or follow, lemme know, and I'll go to MY 19 and screen shot the screen progression for U. Now I got a lowly Bighorn (8.4 Screen, Plain Jane U con 4 radio), not all the fancy setups lmao.
joesstripclub
Lees Summit, MO
2021 2500 PW
OasisNinjaBat
