Wide wheel problems
Dryates
Sorry if this has been answered. Anyone with 10 or 12 wide wheels have any short or long term suspension problems running wider negative offset wheels. I know the ball joints can be a problem, but better UCA should fix this. Just wondering what to look forward to by going wider and negative. Also how much of a problem difference would there be in a 20x10 -24 vs 20x12 -44 with the same tires 33x12.5r20
Robocop_9
West Virginia
I'm running 33x12.50 on 20s with -24 offset. I'm running a level. I replaced my UCA with mevotech because of the ball joint issues. The -24 offset will set out pretty wide. I suggest flares
Witch
Hemi 5.7 liter
I just put on Zone UCA's in anticipation of -12 offset wheels and the 2" spacers I have coming
Running 37x12.5 r20's
Dryates
Dryates
What size you running?
14blackouthemi
North Jersey
I have 22x12 -44 offset on stock suspension zero issues
VB712
Maxi_built
Va Beach
20x12 -44 offset here without any issues. Only been about 500 miles though.
Robocop_9
West Virginia
yup and kept it at 2.1 partly cause i like a lil rake and partly to avoid uca issuees
From what I've seen if you run bilsteins you won't have the issues. A lot of guys here with bils at 2.1 and no issues. I'm running a 3" spacer and it pushed my ball joints up after 3-4K miles. I went ahead and swapped my UCAs for mevotech
Mr.AK902
Regina,SK
17'
Difference between -24 and -44 offsets is 20MM negative in the difference. In other words, the hub mounts to the rim surface 20MM closer to the vehicl with a -44 offset then that rim of a -24 offset. This pushes the rim out 20MM further, or in other words the better part of an inch.
I've had both offsets in the past. -44 pushes the wheel out 3+ inches or more. Personaly i think -24 looks the best, especially on a stock height truck. My next set of rims will be -24 at stock height suspension
