Will 2013 backup camera work on 2009?
mrack
I have a 2013 and a 2009, both 1500s, the 2013 is a project to flip, but I’m keeping the 2009. Is it possible to swap everything for the backup camera from the 2013 to the 2009? I know the canbus is completely different between the two, but since the camera screen is in the rear view mirror and not the radio, I don’t believe the backup camera is affiliated with the canbus at all?
DrJones86
Did you ever get an answer on this or try the swap?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The 2009 Dodge Ram 1500, was the first year that CanBus C was used by Chrysler.
2 of the Jeep models also used CanBus C in 2009
CanBus C is also referred to as HIGH SPEED
CanBus Low Speed was still used in the rest of the Chrysler Fleet
The easiest way for me to tell, which CanBus a vehicle has, is to look up if the Radio is High or Low Speed
Most businesses make a written statement, when it comes to High or Low Speed canbus
This radio does not require programming its a plug and play model. This unit will ONLY work in vehicles with the high speed CANBUS system.
Dodge Ram Truck 2009 2010 2011 2012 Factory MyGig 30GB Highspeed Media CD Player Radio P05064245AL REN (OD2708-3)​
