Will these rims fit?
shawn1112
Streamwood IL
Searched and couldn't find a definite answer. I have a 14 Laramie and want to pull the trigger on these rims. I plan on leveling with bills but not ready to do a lift if that's what's needed.
22x12/-44 offset fuel hostage rims w 22x12.5x35 nitto
CLOUDL1GHT
Lone Star State
Cummins HO
i know people fit 20x12 -44 on a leveled truck with 33's and minor rubbing
35's will probably be a pita without a lift imo
S
shawn1112
Streamwood IL
These are 22's, so with you saying 20x12 are an issue without a lift, I'm assuming no way the 22's fit?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
No, you won't fit 35x12.5's on 22x12 -44 offset wheels with only a leveling kit on a 1500. You'd need a 6" lift to make that wheel/tire setup fit. If you only want to stick with a level then you'll need to step down to a 33" tire and you'll be trimming to get the required clearance.
Wandell
Cummins 6.7
And wheel diameter doesn't matter. It's all about the wheels width and backspacing/offset. Doesn't matter if it's a 17 or 24 inch diameter wheel.
S
shawn1112
Streamwood IL
Thank you Wandell, that's why I'm here.....to learn from everyone.
Steve58
