Win module issues
bhill115
Pa
I have a 2012 ram 2500 5.7. I am having an issue with the key fobs not working and saying they are the wrong key on dash. I get no power lights on dash when turning key to on position. I have a scan tool to reprogram the keys but I can't get communication to the obd port because the key won't turn on the power. So I can't use my scan tool to reset key fob. I'm dead in the water and any help would be appreciated.
bypass it so you can move.. Not sure if it is win or pcm though. make sure you use cig lighter relay./
B
bhill115
Pa
I would try that but both key fobs don't do anything when I turn to run position. Only thing on dashnis a wrong kwybon the display other than that I get nothing like no power to dash
B
bhill115
Pa
Sorry my fat fingers on this phone mispell alot. I meant only thing on dash is a wrong key display when I turn to the run position
ThatSilver2010
I have tried this in the video, my truck would turn over but wouldn’t fire. What am I doing wrong?
did you use same relays? It was on a 4.7 and not a hemi? did you hear the fuel pump?
ThatSilver2010
Could it be I had a bad connection, wrong gauge wire, or a wimpy button?
Not the same relay as the video, but it was the starter relay. Fuse box was laid out differently altogether than the Cummins in the video. I did not think to listen for the fuel pump
TheM4rxxx
