Window decal peeling
Taylor513
Phoenix
15CF816F-77D4-4336-8C8F-21458E5897D7.jpeg 581CB7BA-2EF6-4B5B-84CA-14F00367B426.jpeg E8B239E9-9002-46B1-95A5-0C168A0CDF02.jpeg DFC30801-6001-4FC0-9E4A-A004B1E678FF.jpeg BBF2B967-0B30-4A8A-B6C2-A281999885F0.jpeg Wasn’t exactly sure where to post this or what they’re called but the window decals on my passenger side has chipped and gotten a little jagged. Is this common? Or is there anyway to fix this or replace them? Also I’ve noticed that when I turn my windows in they cut into my weather stripping anyone else have that issue and a solution other then to not use that feature?
Thanks for any advice
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
I removed the vinyl wrap by the windows as mine was doing the same thing. In my opinion the Ram looks better without it and it serves no purpose other than asthetics. As for the lower rubber, I don’t know what that could be from...
Taylor513
Taylor513
Phoenix
What’s under the vinyl wrap? Is it color matched under there
ClarkandAddison
IN
Yes, it's painted the same color as the truck. Lots of people on here have removed theirs.
werdna1977
Ontario, Canada
Yes it is very common for this to happen. Depending on the age of your truck and warranty remaining it is covered if you want it replaced. I have had my old 13 and 15 ram done in the past
Taylor513
Taylor513
Phoenix
It's a 15 ram and just hit 36K miles so i'm not sure if its still under warranty or not but I might have them look at it and then check out the window too that digs into the weather stripping
ctdodge
Bristol, CT
2017 Laramie 1500
Actually I like having it there. I make a point of closing my door from the pillar so I don't get fingerprints all over the door edge
grizzstang
Calgary, Alberta Canada
Looks better without it to me. I peeled mine off after a few months.
full
zogg
Southern Illinois
2018 Ram Express Quad Cab
Yep...what he said!!
Taylor513
Taylor513
Phoenix
It’s all over the Internet, super easy- Do it when it’s warm and get some “Goof off”-
Haha yeah now that I know what i'm looking for I'm seeing it. It's a little chilly still so I'll probably have to use a blow dryer to heat up the adhesive to get it off. I'll post a before and after on this forum after
Taylor513
Taylor513
Phoenix
That's the one reason I like it. I also use it to close the door so I dont leave prints after its washed but it also doesnt look all that great chipping and having wrinkles
AKArmendariz
Mine was doing the same thing and it looked super cheap. Since my window tint is kinda dark I ordered a gloss vinyl to replace it to have it flow between my windows and I love the way it turned out.
Taylor513
Taylor513
Phoenix
View attachment 153680View attachment 153681
Damn that does look good. I have limo (5%) all the way around so that would help it flow. Now you got me debating which route to go with
AKArmendariz
If you want more before and after pics let me know. I also have a lot of the vinyl left over that I would be willing to give you if you decide to do yours this way. [emoji1360]
Taylor513
Taylor513
Phoenix
Awesome, I appreciate that! I'll let you know if I plan to follow and do the same
Doug70767
